CIBSE GSHPA HPA
Groundwater Source Heat Pumps
Code of Practice
GSHPA and CIBSE have published a code of practice for Open Loop Groundwater Source Heat Pumps.
The Code of Practice, which was produced by a steering committee with lead authorship
from Nic Wincott and Jen Billings of the GSHPA,
is available from CIBSE CP3.
The CP3 Open-loop groundwater source heat pumps: Code of Practice for the UK,
looks at the huge opportunity to provide low carbon heating and cooling to buildings from aquifers and mine water
using groundwater source heat pumps (GWSHPs).
It aims to raise standards across the supply chain and encourage the adoption of groundwater heat pumps.
CP3 Groundwater Source Heat Pumps - Code of Practice
Phil Jones (Chairman of CP3 steering committee) said on the launch, "The rapid decarbonisation of the electricity grid means that
heat pumps are THE low carbon solution for providing heating and cooling in buildings.
Groundwater provides a relatively constant temperature source, making GWSHPs an efficient technology right across the year.
This new Code of Practice sets out minimum standards to give the buildings sector confidence in applying GWSHPs correctly."
Ground Source Heat Pump Association Chairman, Bean Beanland, is delighted that further collaboration with CIBSE has delivered
another excellent Code of Practice. Ground and water source heat pump technology is extremely well suited
to the UK climate, and is the technology of NOW.
The recent Committee on Climate Change report on Net Zero emissions for the UK by 2050 requires immediate action
with technologies that are tried, tested and available now. The potential for carbon emissions reduction is considerable and,
in addition, heat pumps have a major contribution to make to air quality improvement in the urban environment,
being zero NOx, SOx and particulates emitters at the point of use.
The GSHPA is keen to work with CIBSE to promote heat pumps and the Codes,
as specifiers increasingly turn to ground and water source heat pumps to satisfy Building Regulations,
to meet increasingly demanding local planning conditions on emissions,
and to deliver the low carbon buildings of the future. These are increasingly being demanded by home owners,
the domestic rental sector and by commercial building owners and tenants as social awareness develops
and as increasing carbon taxation looks set to become a reality.
Groundwater Heat Pumps and Fifth Generation District Heating
Each succeeding generation of district heating has moved to a lower temperature of heat distribution:
this reduces the heat losses to the ground from connecting pipework between buildings
until the current Fourth Generation District Heating which distributes hot water at around 65°C.
The next logical step is to move to circulating water at ambient ground temperature in the network: Fifth Generation District Heating.
This eliminates heat losses to the ground and reduces the need for expensive pipework. It also eliminates the need for a central "Energy Centre".
A Heat pump in each building extracts heat from the network when its building needs heating,
and rejects heat to the network when its building needs cooling in summer.
The ambient ground circuit will need to balance its temperature with a source of heat
and the best opportunity to do this is likely to come from groundwater using groundwater heat pumps.
See GSHP Case Studies, including examples of groundwater heat pumps
and Fifth Generation District Heating and Cooling.
To get the full benefit of a GSHP installation or a GWSHP you will need to employ someone with design and installation
experience. A groundwater source heat pump, like a ground source heat pump, may not perform well
unless it is incorporated in a good design by someone
who understands the needs of the building, the use to which the building is being put and the local geology.
Risks of fragmented responsibility
The same thought is expressed on page 7 of CP3 in the following words:
"A successful open-loop GWSHP project is often made more difficult by the
fragmented nature of the industry and complex procurement processes. It is common
to find the feasibility work is carried out by a consultant, the detailed design and
construction by a design-and-build contractor and the operation and maintenance by
an unrelated facilities management company. The procurement approach adopted
should consider the risks involved in this fragmentation and lack of incentives for
each party involved to deliver an optimal scheme".
In addition to the risks of employing fragmented parties, there may be a lack of responsibility for the whole design,
installation and operation if more than one party is responsible for the resulting performance.
To ensure a "soft landing" you should ensure that a ground source system is well understood and well maintained
and this may include fine tuning the controls in the first years of operation.
For more information on installation of ground source heating from an experienced source
please contact one of our members.
