Shallow Ground Source Standard
The third GSHP Standard to be published is the Shallow Ground Source Standard which covers Horizontal Ground Heat Exchangers: Design, Installation & Materials Standards under the following headings:
- Government and regulatory agency requirements
- Design & installation - personnel & training requirements
- Design methods and compliance
- Soil thermal conductivity testing
- Ground heat exchanger pipe materials & jointing
- Groundworks
- Pipe placement & backfilling
- Flush, purge & pressure test of ground heat exchanger
- Pumps, manifolds & pressurisation
- Thermal transfer fluids
- Design drawings and records
- Submittals & alterations to Standards
To buy a copy of the GSHPA Shallow Ground Source Standard please click here.
If you are a member of the GSHPA we can send you a copy of the Shallow Ground Source Standard if you: click here.
